To Laundromat:
To quote:
"as well as their tiny 12 pound capacity" - Do you really think that was tiny? In 1963 is was about par for the course if not a little better than par.
"I'll bet the only things needed on the washer would be a new tub seal,new rubber hosing,a new wig-wag,new belt, belt adjustment and new intake hoses." - That's all?? A tub seal can be a decent amount of work in a vintage machine (see volvoguy's current thread). New internal hoses for this machine would largely have to be made to fit, as the originals are all NLA.
You need to be careful what you advocate about these older machines. A nice design in more ways than one, yes, but without an inspection, you can't ascertain a machine's overall condition based on this ad, and you should be careful when speculating. I would not suggest a nearly clean mechanical bill of health as you did, as your comment might cause some unknowing person out there to spend a great deal of money to get the sought-after Pink Ladies thinking they are an easy fix at worst, and wind up with a potential money pit or two. True that the machines might be mint perfect, but until someone in the know checks them out, we should remain mindful of getting hopes up.
As to all that the machine would need, you've left out some MAJOR potentials in the washer, including the most likely, which are bearings and shaft and spin tube seals. Unless the machine has had very limited use, or unless its bearings have already been replaced, there is a very good chance the original bearings are beginning to wear or worse. Once they start, the machine is not pleasant to use and will eventually become unuseable or very finicky at the least.
These are awesome looking machines. If they were inexpensive (that's a definition up to each person), I wouldn't be so concerned about their mechanical condition, because someone here can fix them. But at $1800, or even $1000, they'd better be new in box or nearly so unless the buyer knows what he/she wants and has the resources one way or another to get them into operating condition.
Gordon
