Gas 24" WP-KM Compact Dryers
These were built from the late 60s till sometime in the early 2000s, after that you could only get the gas 24" dryer as a part of the 24" Thin-Twin.
I have at least 4 used gas compact dryers, including one KM version that was never used if someone wants to buy one, mostly almond maybe one or two white ones.
If you use a flex-line with quick disconnect like you use on an outdoor gas grill the dryer can be used as a portable, I even had a customer lift the top burner out of her older Roper gas range and attach a hose to the orifice and hang the vent hose out the window of the apartment she rented to dry laundry.
John L.
