Launderess's Finds Of The Day
The harvest WP dryer apparently is an Imperial, can't clearly read the console labeling.  The timer has timed drying and one auto-dry cycle (instead of the usual separate Regular and Perm Press) with a Finish Guard extended tumble section ... and there appears to be a moisture sensor on the bulkhead, which explains the single auto-dry cycle, although I thought Finish Guard and electronic auto-dry would reasonably be only on the Imperial Mark 18 of the time.  Finish Guard may be controlled via the temperature selection (Perm Press and Knits, as via the IM18's temp pushbuttons), else it will function for all temp choices.
