Lead on a GE Filter-Flo
DADoES
Moderator
Staff member
May 21, 2001
16,118
TX, U.S. of A.
I have access to a GE Filter-Flo with mini-basket. 2 speed, 7 cycle. The seller initially said it's in good working condition, except the timer knob has a stripped screw which makes it difficult to turn/set. However, after advising her to look underneath, she discovered it is leaking oil. She didn't say how much, just that there's "some kind of oil." I can get it for $50, or maybe less since she's now aware of the oil situation. Is it worth that as a fixer-upper? I don't have a specific source for a replacement GE tranny, would have to appeal to the masses or something, LOL.
I also had a lead on Maytag pair, belonged to an elderly woman who sold her house and moved to a nursing home. Don't know the age or models, but someone else already took them.
The GE is in Austin, but the seller's parents live here. She was going to bring it next Wednesday when she comes for Thanksgiving weekend. I told her I'd let her know by Monday evening.
No one has any repair advice on this GE? I don't have much know-how on GE, but I'd like to learn. Is replacing the transmission the only reasonable fix for an oil leak? Or is there a gasket or seal that can be replaced at less cost and effort? A new transmission is $156 (assuming that's the one) at RepairClinic. Are used or rebuilt trannys available from an alternate source?
If I see a filter flo that leaks oil,I usually pass.They are still quite abundant,at least around here.And with the timer problem? $50.00 is waaaaayyy too much to pay,unless it's an early 60's model,or something special.My advice is given free,value accordingly.
kennyGF
Glenn, $50 for a Filter-Flo with an oil leak is way too much...for your sake don't get it! Unless it's a 60's model, or very latest, early 70's.
I wouldn't have paid $20 for my Dispensall if I saw evidence of an oil leak on the back panel. In fact, someone couldn't even give one to me if it had that problem...
Just my $0.02. Will let you know more this afternoon.
The seller doesn't have pics, has not told me the model number or age, although I have asked. I can't see the machine until she brings it town, and I don't want her having to haul it over here if it's bogus. All she says is that it is in "good" working condition other than the timer issue, they've been using it, they didn't know it had an oil leak (until I told her to look). I asked, she won't go lower than $50, even with the oil situation.
So, I'll tell her pass.
I have replaced the seal on many GE's. They can be installed without removing the trans. You have to turn the machine upside down of course.
Agree with others. $50 is too much. Free is about right if you really want it bad.
I have seen the occasional GE filter-flo on Ebay. They usually start at .99. A ge with an oil leak on the bottom isn't sooo bad. It just depends on if the oil has got into the motor. Be prepared to work outside with good ventilation, rubber gloves, paper towels and some paint thinner getting rid of the oil.
I would rather change a transmission in a GE Filter-flo than deal with a Kenmore/whirlpool belt-drive oil leak.
