LG washer died - look for old direct drive?
meldew
Jul 20, 2018
99
Georgia
Hi all,
I posted 3-4 years ago looking for buying advice; ended up with a new LG FL with turbo and steam. It's been.... okay. But it's finally died and tbh I don't want to fix it. Here's what the problems have been: Turbo wash quit completely, so if I forget to cancel the turbo option, not all the clothes get wet. Normal wash cycle will not go into spin so it eventually times out, so I have to remember to use PP or HD wash cycles instead. Finally, it will no longer drain and makes a horrible sound when I try to drain & spin. No water from drain tube either. I needed to use Lysol laundry sanitizer or clothes all stink. I'm just sick of it and want to go in another direction - I think.
We are building a house rn so I was planning on buying something in a couple months but need it immediately. Thinking of going to used appliance shops in the area and seeing if they have any older direct drive TL machines. Any advice as to what to look for? How do I know it's the correct motor setup? Will it say direct drive somewhere or dependable care or something lol?
Our needs: our new build is on well and septic. The well only gets max 4gpm with a small reservoir in the 6" borehole so I'm a little nervous about a high water usage machine. I have 4 kids at home and do lots I mean lots of laundry.
Should I just get a SQ FL? Or an old DD TL? Or a TC5? First I need durability. We are so hard on appliances. We will be living on a muddy river and ride horses so the washer will have to deal with a lot of sand/silt/mud. The laundry room will have a utility sink so I hope to rinse dirt off there first to save the washer from having to do it.
Lastly I don't want to spend more than I have to - building in this economy is expensive already. I even thought of just getting a cheap Amana but I'm afraid it would just be disposable for us and have a short life. I do at least 2-3 loads a day minimum, and after a trip it's half a dozen loads per day for a couple days. Not counting horse stuff.
I do plan to utilize a clothesline at the new house. And a dryer when needed. Will need a new one as the matching LG dryer no longer heats on normal for some reason so I end up doing several cycles of PP to dry our heavier clothes.
Thanks for any input!
Dealing with vast amounts of mud and sand may be one of the few things top loaders are actually as good as or perhaps even better than front loaders at. But a front loader can certainly do a great job at that too (ask any European farmer, etc.). My best advice would be to make sure that whatever front loader you buy - should you not go for a top loader - has a prewash option. Not sure about you guys overseas, but I've encountered quite a few machines here that have done away with the prewash altogether. It really is the best way to wash clothes that are heavily soiled in muck and debris, as it gets rid of most of it before the main wash. In terms of stain removal and water usage, a front loader would be king, as we all know.
Not American here, so can't give direct buying advice, but I know that you guys have Miele machines over there, which I would absolutely normally recommend to anyone known to do *lots* of cycles, but I find that the honeycomb drum design isn't great for large amounts of debris, so I'd maybe steer clear of Miele altogether.
thanks I wondered about Miele. I don't mind smaller loads; after all we will be empty nesters soon enough. I think durability is definitely king. Thanks for your input.
LG Turbo Wash
That was one of my concerns with Turbo Wash. I do not believe they have a separate pump and filter for recirculation like Miele does with their IntenseWash. Certain lifestyles could be very hard on Turbo Wash while others Turbo Wash could work just fine.
With your lifestyle and if you want recirculation, I'd go with Miele. If you are on a budget and don't need recirculation, you could go with the LG 3600 and use the prewash. Or you could go with the Speed Queen FL if you have a larger budget, want more longevity, and don't need the heating element.
I have a Speed Queen 9 series. While it's not the best for stain removal; it is amazing for getting mud, gunk, and pet hair out of clothes. It's a great all around washer that is very well made. The TC5 is very similar to it and I wouldn't hesitate to get a TC5 if I wanted another top loader.
If I were you, my first choice for your particular needs would be the Speed Queen FL. It's a commercial quality machine that is made for tough lifestyles in mind.
I think your lg turbo wash is plugged up. They use the same drain basket catch. a drain pump on the left side and the recirculating pump on the right side. Really it could be fixed/cleaned out and start working again. Using the towels cycle will certainly help with rinsing out gunk on your clothes.
Going forward, I think you just have so much grime on your clothes, I think a SQ tc5 would work best, it has a mechanical pump (to my knowledge) and would provide enough power to get all the gunk and grime out.
SQ front load would work really well, I’m just concerned for the pump. Though they are very easy to service.
I have a Miele with honeycomb drum. If I was grassy stuff, it will not wash out, I usually have to vacuum out the tub before putting in a load. So I don’t recommend that.
Normal wash / needed to use Lysol
How often do you use the Normal cycle? It's by far the stingiest when it comes to water consumption and water temps. A seemingly deep-cleaning hot wash is probably only warm and a warm wash is mostly cool. This, along with low water consumption, can lead to smelling clothes.
I extremely rarely use my Normal cycle. My "normal cycle" is either Perm Press, Whites, or Towels and simply adjust the wash temp to meet the load, not what the default water temperawture is. Normal, "hot" is 95F and warm is 83F (unacceptable temps to me). The cycles I mentioned has warm of 90F and Hot of 112F.
John, it was me. This applied only to the Normal cycle. Warm target temp was 86F. Hot was 95F. But setting soil level to the heaviest on Normal, then target temp is 104F. For Normal & Heavy Duty cycles, the heater does not come on the boost or maintain water temperatures. the only time the heater comes on for thesse two cycles is when Extra Hot is selected. Target temps for towels, perm press. & whites is 90F for warm & 112F for hot.
got a new washer
So thank you everyone for the advice. Yes my LG can probably be fixed. I will give it to someone who wants to... I'm just frustrated. So I needed to do something. I found a washer and dryer (I don't think they are an exact match) on marketplace and bought them. The first load is running right now.
They are both Kenmore. The washer serial number says manufactured in 2004. It says 80 series 3 speed motor with 5 speed combinations... dryer says Kenmore elite. How did I do? Got them for 325 for both. I don't see any rust.
washer seems to work great! Dryer not so much
The auto sensor seems to be bad - if I set it to More Dry I can watch the dial slowly move to dry over about 3 minutes. clothes are obviously not dry! Timed dry does seem to work. Also, I need the dryer vented to the right side. Does anyone know how I figure out which side vent dryer kit to buy?
Would add photos but I'm not able to for some reason.
model numbers!
washer is LSR6334LQ1. says whirlpool on label?
dryer is 110.60932990
Dryer is definitely taking too long to dry on timed dry/cotton
I did call the local shops regarding the SQ. They told me it would be about 6 months to get an FR7 front loader, and a few weeks to get a TC5. They had several TR3 and 7 in stock and recommended those instead. I thought I'd try out this old set first.
LSR6334LQ1 is a Whirlpool washer model number.  Perhaps the outer cabinet and top deck, or only the top deck, with the label attached was transplanted to a Kenmore.  Or could be the other way around, a Kenmore panel was transplanted to a Whirlpool.  Either way, you don't have/know the model number to match the Kenmore controls.
110.60932990 is a Kenmore model number, Whirlpool-built per the 110 leading digits.
The dryer, assuming the model is correct, has an electronic board, I believe referred to as an Even Heat board, that controls timer operation for the auto-dry cycle.  Is there labeling on the console referencing Even Heat or Auto Moisture Sensing Plus?
This info may be helpful ... or not, if it isn't the problem.  There are other symptoms that also typically occur for Even Heat failures.
Even Heat Control
Even Heat problems
The board, if it's the problem, is NLA for new replacements but used and repaired boards can easily be found, and repair service offers.  P/N 3976617
