Lint problem Maytag
billt
Jul 2, 2019
LUNENBURG
Have a Maytag Legacy top loading washer about 10 years old. Clothes are beginning to come out covered in lint. I have cleaned the washer tub area as best I can. I can't find a lint filter anywhere. Agitator won't come off if it's in there. Any help out there?
common issues with lint...
over loading, over sudsing, too long/aggressive wash time, separate lint givers from lint attracters...
there are times lint leftover from a previous load will attach to the next load...
the so called lint filter on yours should be under the agitator...although not very effective, it does filter out some lint...
most likely your Legacy is a Norge built design, into which, a bolt under the fabric softener dispenser holds down that agitator....
other Newton built Maytag agitators either pulled straight out, or have a set screw removable from the side of the barrel...
