Looking for help deciding what type of washer to buy....
shneire
Jan 29, 2018
6
MN
Mom of 5 looking for a new washer to replace my awful Kenmore HE FL. Can't stand the fact that the washer does everything and I have no control over any settings and all clothes coming out stained/still smelling dirty. Totally disgusts me...anyways...been reading about speed queens and about the 2018 models being re-designed in a bad way. Found a couple local places still selling the last of their 2017 models. But also wondering if I should buy used. Found a pair of older-looking maytags (pics included). Owner says they were bought in early 2000's, and they are in great condition. Model numbers from owner are LAT7500 and LD7500. Good buy? Should I stay away? Detail oriented and don't want to buy lemons!! Husband can do some appliance work himself so want something that can be easily fixed if it breaks. Just want it to do the 1 job it's supposed to do which is to give me CLEAN CLOTHES. Thanks for any advice/info you can give!
Dryer pic
Here's the owner's pic of the dryer he sent me. Sorry they're not great pics. Just wanting to know if these machines are worth purchasing or not. What I really want is to choose my water level, plus be able to see the clothes as they agitate during the cycle. In order to add more water or add more clothes if needed. Thanks!
Exterior looks mint ... but no pic of the interiors, and the mechanicals can't be ascertained without examination.
The serial numbers will confirm the age.
Get the seller to send a pic of the washer's lint filter, or ask how often it's cleaned (many people either aren't aware there's a pull-out filter in the agitator or just never clean it).  The condition of the filter may be a clue to how well-cared are the machines.
Those Maytags
Are very reliable. Weak point on the washer is the tub seal, the other breakdowns are very minor. The capacity is small, like half of your front loader. Wash action is good compared compared to newer machines, but there are better ones out there.
The dryer is solid, the occasional belt, blower wheel, etc.
Based on the pictures it looks like those are in good shape. Even if the washer needed a tub seal I’d still buy it and fix them.
Mom of five?
Honey
For you its a complete no-brainer - if you like a traditional style washer get a 2017 model Speed Queen while you can, you won't have the time to be messing around with an almost 20 year old washer if it breaks down. If its a little too pricy there are several good front loader options out there at different price points, if you feel like making the change make sure to get one with an internal heater.
Good luck in your seach
Al
I'd recommend the 2017 Speed Queen top-loader, as well. Have had one since the end of July and it does a great job. I have the top-of-the-line 9 Series with the electronic controls. Bought one for my sister and she likes it, too.
The lid switch can very easily be disabled with a clothespin before you put the washer up against the wall. It clips onto a brace on the back of the washer. Super simple. But, that means it won't stop during a spin, which may be dangerous in a house with kids.
I'm sure you do many loads of laundry each week with five kids. Go with the new machine that is repairable if/when something eventually needs attention.
However: Be prepared for increased water/energy bills compared to your front-loader. Front-loaders had been my "daily driver" since the mid-1980s, but moved to an apartment this summer with a very tight laundry space.
I have an Excedrin Headache
<span style="font-size: 14pt; color: #008000;">So many Speed Queen videos. So much advice on don't buy this one get this one. I do understand the apparently very different product the 2018 top load washer is from previous top-load Speed Queens.. Is this model, AWNE92SP a 2017 model? If so perhaps I should snag one before they're all gone. </span>
Yes.  That's the Speed Queen washer I have.  No complaints, considering it's basically a washer that could have been beamed in from 1955.
Minor quibbles--
1) Agitator-mounted softener dispenser means softener is added to first rinse if extra rinse options are selected.
2)  No detergent dispenser means you have to come back to the washer to add detergent when it advances from soak or prewash to main wash.  (Never use those options; I soak for 45-60 minutes by powering the machine down.)
3)  Can't select warm or cool water for soak/prewash followed by a hot wash.  Whatever temp you select is used for soak/prewash and main wash.
Note:  The capability to do any of the above is generally derided by SQ fans as a silly bell/whistle/frill.
[this post was last edited: 1/30/2018-13:57]
Decisions decisions
Thanks so much for all the info. We are leaning towards the 2017 manual control (knob style) speed queens. Much more control with water levels and changing the rinse water to hot/warm by turning back to the beginning of cycle to let water fill up, then switching back to rinse. At least I hope to be able to do this on the SQ...as I could on my old TL whirlpool. Definitely need something reliable so even though I'd love to buy the set I posted pics of above just to have them as extras to play with, will forego those and buy the workhorse SQ instead. Hubby doesn't always repair things timely just because with 5 kiddos there isn't much time anymore!! :P Still seeing the 2017's in stock but supply is dwindling everywhere so if you want a set new get it quick! I'm not thrilled about the bigger water bill as we already have issues with that. But hate the constant stained, and still-stinking laundry, so oh well....pros and cons!
for the Pre-wash/Soak going into the main wash without a dispenser....
the actual idea is to double the detergent at the start, the heavy concentration at the start will work out tough stains, and there will be enough left over for the rest of the cycle to work with....
without the double dose, you sort of defeat the soaking option.....
and of course the extra rinse will take care of all the suds....
YMMV
Shannon-- You can also do any of the things you mentioned in the post above with the 9 Series electronic controlled model.
For instance, to save soft water (Culligan exchanges a tank for me each week) I often fill the machine with hot water, press the power button to shut it off, then switch to the Normal Eco cycle, which does a water-saving spray rinse.
To get a hot or warm rinse, power down the machine, select a cycle and let it fill with warm water. Press the power button, then select Rinse/Spin.
Some people are more comfortable with knobs/dials. I tend to prefer electronic controls.
Personally, I think a Speed Queen would be a good fit for your heavy usage situation. They are generally quite dependable. More importantly, they are repairable when the inevitable happens.
At any rate, good luck with your purchase decisions, and please do let us know what you wind up getting. We love follow-up!
Here is an excellent standard laundry pair being sold in your area. The dryer is of a design touted on these boards as the best all around consumer dryer ever made. The Washer *i believe* is it's equally beloved "direct drive" Whirlpool design in Kenmore garb...another work of greatness in all around laundry utility.
Someone who knows please chime in if I am wrong. But if my suspicion is right, that price looks to be a bargain.
As mentioned above, old machines will keep you busy fixing them. And let me tell you from my recent experience (see pics 2-4), pounds of filth can be found lurking inside. These look to be fairly new and well cared for. The money you save will cover many years (decades if you factor in the lower repair costs) of higher energy/water expenses that top loaders like this will use. More energy because you run more loads; and they are, compared to He machines, water hogs.
The front load craigslist offerings in your area are not as good, that said, if you're patient, and ready to pounce, they do seem to turn up regularly.
[this post was last edited: 1/30/2018-14:44]
As Dadoes mentioned above, Miele is a German brand that makes good quality front load machines that will last a long time. The problem is they are quite expensive to buy new, replacement parts are expensive too and they're about 1/2 the capacity of the "American size" machines. The other issue is (at least these older models) they require 220V power, yes even the washer. A regular cycle on these machines is 1h 40m start to finish. The up side is they have built in heaters and many, like the machines pictured below, can do up to a 190 degree wash!
I bought these at a yard sale last April and they're 19-20 years old. After replacing the tub shocks on the washer, they have been working great since!
Kevin
