looking for replacement coils
elinorw88
Sep 13, 2020
9
Lilburn
Hi all!
One of the coils is not working on my Super Frigidaire Poppy Red Stove. I am heartbroken. Does anyone know where I can get replacements? Or what part to even look for? Any help would be appreciated!!
I find many appliance parts at Repair Clinic. The model number in your picture was not listed but they do carry elements and many other parts for Frigidaire stoves.
Here is an element that looks similar to your picture
https://www.repairclinic.com/PartDetail/Coil-Surface-Element/316442300/1465860
Is size matters:
6 inch https://www.repairclinic.com/PartDetail/Coil-Surface-Element/318372210/1615642
8 inch https://www.repairclinic.com/PartDetail/Coil-Surface-Element/316442301/1465861
PartsDr is usually less $ than RepairClinic.  Find a suitable item / part number, shop it at all available sources.
I agree with everything John (combo52) stated above.
Over the 60 years that my mom had her 1949 Westinghouse stove, broken wires were re-attached to burners a few times.
I also agree that broken or loose wires are more likely the problem.
I would take the burner unit out and try it in the spot of one of the burners you know works. If it works there, you'll know it's either the wires or the switch.
RE: Post# 1135616 ,
Those Repair Clinic replacement coils are not the original Frigidaire coils. Frigidaire had unique wide coils on their stoves and cooktops. Check on Ebay. They seem to pop up every once in a while.
