Our 12yo Kitchenaid dishwasher (model kuds01dlss6) used to run quietly but now makes a loud, consistent groaning noise during the wash and rinse cycles.  The drain and fill cycles are still quiet.  I removed the parts inside the dishwasher down to the food grinder area to remove any foreign objects -  which there weren’t many since we rinse in sink first.  I also turned the impeller via the grinder and it seemed to turn smoothly.  However, the sound still persists.  With the bottom front panel off, the sound definitely appears to be coming from the circulation pump area.  From what I have read, the motor bearings are the likely suspect given the potential of a shaft seal leak and the age of the dishwasher.  Although I saw no signs of leaking from underneath, I know from pool motors that even the slightest of leaks can rust out the bearings.  A replacement pump/motor can be had for less than $150.  Would anyone who has done this repair care to comment on difficulty, other issues that may arise or if I am barking up the wrong tree?
Also, given the dishwasher is 12 years old, are there other commons issues that I should look for or consider before deciding to repair versus replace? Not sure of the longevity of these dishwashers. From poking around the inside, everything look in decent condition except for one or two rusted rack tines.
Thanks in advance for any advice.
