fltcoils
My Kitchenaid dishwasher only fills half full. It needs 3 gallons and only gets 1.5 gallons during the timed 2 minute fill period. The unit is a portable, Series 57 (series 17 portable).
I've cleaned the water filter section of the fill valve. vinegar soak. (caution: a vinegar soak will strip off the plating from the fill valve bracket.)
Flow currently from the faucet, hose, fill inlet and screen is about 3 GPM. So something downstream of those, the fill valve, supply tube or tub inlet orifice must be choking the flow.
Suggestions?
Suggestions?
