Malber TD700 Dryer not turning on
burt
Feb 28, 2021
Flushing
I have a Malber TD700 dryer, stacked on top of a Malber washer. I used it the other day, with no problems. I then tried using it again about an hour later and it simply would not turn on. Usually the on button stays depressed and the light turns on, but here the button will not stay down - and even if I hold it the light (and the dryer) do not turn on. I tried unplugging the machine over night, but without any success. I thought maybe it is the door mechanism. I tried manually pressing it. One time I got the machine to turn on for about a second - but I'm not sure if that was a fluke or a real indicator that the door is the problem. I've tried the door many times since that once, but no success. The outlet seems to be working.
If anyone has any suggestions, that would be appreciated!
