I just replaced the belts on our Maytag 608. The washer was working fine until the replacement. I replaced the motor mount springs and the nylon wheels. The new pump belt seems very loose, but the old one was too. It's easy to touch the belt together at the mid span. The instructions called for 1/4" separation, but there seems to be zero now. I moved the pump to its extreme position to increase the belt tightness, but it still seems rather loose. Now the washer doesn't drain.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
