Maytag A107 Automatic
idunno
Jul 18, 2009
2
I have a Maytag A107 automatic that will not continue on its own thru each cycle - If you manually advance the machine using the dial it will operate in each stage of the wash/rinse/spin/etc..., but will not advance on its own - it's very laborious having to baby-sit the washer thru the process.
Please assume in your answer that your speaking to a beginner, who knows virtually nothing about these issues, nor the "lango"...
Thanks in advance -
Casey
Timer not advancing--
It sounds like either your timer isn't advancing due to either a loose wire or it took a dump.The timer is easy to replace but may be hard to locate.Anyone here that has one???
Thank you guys... I just purchased the part from Ebay - another thanks for adding the link!
I certainly appreciate the quick response.
I am now doing my sheets and pillow cases in my A408 Fabric Matic! it has 4 water levels,One speed,Four temp settings,bleach dispenser,fabric softner dispenser,saok cycles and a white,super capacity(extra large)porcelain wash baskit.I got it at the local dump,free!!
Talk about an ultimate score!
Let me guess, you got it working with a very minor repair?
