Maytag A408- Issue
bingwsguy
Feb 8, 2006
252
Binghamton NY
Hello everyone. I just acquired an A408 washer. It starts right off agitating at normal speed, pumps water full force, and seems to ramp up normally during spin. When agitating it "rattles" or "chatters" a little from under the machine. It is not heard while pumping water during spin, but then once water is pumped out & it's spinning- that noise is back. No signs of leaking grease or water anywhere. Any thoughts? Thank You.
From underneath, push the motor forward and remove the belts. Check to make sure the allen head set screw in motor pulley groove is nice and tight. Re-install belts.
Cavitates
Are you hearing a gasping noise from the pump pulling against the drain during agitation?
Thank You
Thank You for the replies. I ordered a new belt set- just for preventitive maintenance. Once they arrive, I will check all suggested. It does sound like a pulley (metallic noise)
