billythekid
I've got a Maytag LAT8214AAE washer that I bought new in May 1994, and over the last few years the brake assembly has displayed a few very random (< 2 keywords) anomalies. The list includes squeal when spin begins, doesn't engage brake at end of a spin cycle (inside drum freewheels), and fails to release when the machine proceeds from an agitation to spin cycle, and thus smokes the belt. All random failures. This machine happens to have the brake assembly that's held together with 8 hex screws, and in the 1994-1997 Maytag washer service manual, there is a simple procedure to open these assemblies. So now the question: given the behaviors noted, if I open the brake assembly, is there any likelyhood that cleaning and replenishing the oil (automatic transmission fluid for lube, would use Mercon V) in this assembly will cure the noted issues? This assume of course, that there is no obvious damage or wear to any internals. Thoughts?
