J jbellafesta Member Joined Mar 5, 2018 Messages 18 Location Pittsburgh, PA Oct 4, 2018 #2 I'm new to dryer maintenance. Can anyone tell me how long the glides typically last and how one can tell replacement is needed? Thanks!
goatfarmer Well-known member Platinum Member Joined Jan 12, 2004 Messages 9,256 Location South Bend, home of Champions Oct 5, 2018 #3 I don't believe a 106 uses "glides".
combo52 Well-known member Platinum Member Joined Apr 4, 2008 Messages 17,015 Location 50 Year Repair Tech Beltsville,Md Oct 5, 2018 #4 Front Drum Bearing Glides You simply look at them, you can see how thick they are on the ends and compare how much they are worn in the middle, when they are worn to about 1/2 the orignal thickness consider replacement if the dryer gets a lot of use. John L.
J jbellafesta Member Joined Mar 5, 2018 Messages 18 Location Pittsburgh, PA Oct 5, 2018 #5 thank you John.
