Maytag DG712
sst78
Dec 7, 2022
3
NJ
I have the opportunity to have a gas dryer DG712 in working condition. How old is this machine? Any issues to be aware of?
The 712 ran from 1984-1989 and is TOL.
Main areas to check are worn/stiff/squeaky drum rollers, stiff belt idler wheel from lack of lubrication, worn belt, worn front drum glides, excessive play or stripped blower wheel, broken or missing lens for the drum light (check the light bulb too), lint buildup, especially around the motor. Check the condition of all of the seals: Front/Rear drum seals and blower housing seal.
That's so helpful, thank you. Since you also responded to my post about the washer, I'm wondering if the years of manufacture are the same for that one?
Same timeline.
Respond back with the last 2 letters in the serial numbers and we can decode the month and the year of production for each machine.
