Maytag DG906 Electronic Control Unit Compatability
d-jones
Silver Member
Jul 5, 2011
1,204
Western Pennsylvania (Pittsburgh Area)
I have a DG906 that I'm still fixing up for my parents and I recently picked up a new control unit(pn 303049) to keep as a spare. From what I've been able to come up with in going through the archives here this should be a correct replacement for the original part(pn 302472), however, the colors of the dots showing correct placement of the wires have changed. Here's a photo of the original paper label. It's a bit beat up but all of the colors are still visible, though perhaps a tad faded. That one in the middle is supposed to be pink but it got washed out by the flash.
[this post was last edited: 3/21/2014-12:50]
Here's the new one, and as you can see the colored dots are different. The box this came in also contains a small wiring harness that I think may be intended to adapt this part to fit the older installation, but it came with no instructions as to what goes where. I figure I can't be the first guy to have run into this problem, so I'm hoping that at least one of the Maytag experts on this board can help me out with a solution.
Yes, this control is SOMEWHAT different from the one used on the original 1966-1968 electronic control machines that had the wire-wound baffles.  Did the control come with an extra sheet of paper explaining how to use the wiring harness to adapt the 3049 control for use on a machine that originally had the 2472 control?  I have that sheet somewhere…..
The wiring arrangement for this control is somewhat different for reasons which are complicated and not that important to getting this control installed on your dryer.
Let me dig around and see if I can find that sheet...
Hi Mark
There were no instructions of any kind in the box, but the box does have a printed label on it with the part number 302472, so that likely explains why the harness is there. Somewhere along the way the instruction sheet explaining how to use the harness went missing. It'd be great if you were able to find one. I'll keep my fingers crossed.
kenmore71.....
mark:
it seems you must have just about anything & everything maytag!!! I LOVE IT!!!
it is reassuring when someone has a question regarding vintage maytag appliances, that you will have the answer!!!
thank you for being you & always ready & willing to help...
:o)
