The dryer looks more like a newer Hamilton/ Kelvinator/Gibson then the White Westinghouse 4.7 models with cross vane tumbling. These models were "VacuDry" and had numerous flaws. One weekend, Odds see them at the stores and, not long after,the dump or a used appliance dealership. Their washers were o.k. when WCI had the Franklin's with the agitator filters similar to the GE Filter Flows. I just didn't like the indexing and the upper vanes on their agitators. Otherwise,they were o.k. imho. I was just a bit more in tune with the 1--18 machines and other previous RapiDry spinning models. I loved the capacity and perforated tub design burning also the RapiDry. 1000 feature. Now that I own and admire my LGs, the pain and sorrow of FRIGISCARE and their fate has, pretty much,ended. I've had their newer fringes,ranges and front loading pairs. They all work well but break down a lot from just regular use and are expensive to repair. My convection range is not turning the oven element on. It only turns on the broil element then an error code comes on after about an hour and you have to turn the circuit breaker off.
The washers all had become loud from the bearings and/or the spider pullies. The dryers had to be lubes constantly to stop the loud squeaks and the dishwashers suck too. I found an unused one in the box for a hundred dollars and it sucked
