Maytag LA612 Question
elgato
Nov 1, 2023
Arizona
What is the tub capacity of the Maytag LA612?
Also,
I was considering restoring a LA612. The bearing kit is still available. However, the tub seal kit is not. It seems pointless to pull the tub and replace the bearing without replacing the seal. Is this the end of restoring LA612's ?
Thanks
A 612 Maytag top load washer capacity
This is a 19 gallon tub. You should be able to wash 10 to 12 pounds of cotton clothing in it.
Seal assemblies can still be found. If you look there’s also aftermarket ones made now I don’t know how good they are.
It is possible that you don’t need to replace the seal assembly, although if the tub bearing is worn out, it almost certainly has a bad seal assembly.
John
