Maytag N2L Wringer washer on CL for $25
It looks like
It has the drain pump lever, and the drain hose looks like it needs the goose-neck tip, instead of having the hole off to the side, like a gravity draining hose.
This machine doesn't have a "drain pump". It's a gravity drain washer. You can tell by the hose on the washer.
All the pump wringers that I have seen have a hooked end to the hose so that it will hang onto a laundry tub or sink for pump out while the motor is running.
Wow, talk about running it hard and putting it away wet!  This N has seen better days.
While the tag doesn't say it, I agree with Christina.   I too see the pump bracket/lever, and the pump hoses have the straight threaded fitting.  The non-pump hoses have the threaded fitting set at 45 degrees.  Someone certainly could have added the pump along the way.
Ben
[this post was last edited: 6/11/2017-23:33]
