kedsall147
Hi All!
I’m brand new here and although I’ve learned a ton by reading through similar threads, I’m still stuck. I just got this Maytag beauty ($45 - so exciting!) and the woman who sold it said that the wringer is stuck in the on position and runs continuously. No big deal I thought, I’ll just be careful. Well I got it home (on its side With the wringer part pulled out, yikes I see) and when I turned it on things worked. The rollers were going no problem. I didn’t want to run it long until I added more oil in case that was bad. As I’m exploring it I turned it on again and no problem but then they suddenly stopped and no matter what I do I can’t get them going again. If I take the wringer off I see the groves metal pipe spinning. I’ve tried seating it multiple ways as recommended in other posts, I released tension on the rollers and cleaned and reseated them. I can move the bottom roller with my hand slowly. It doesn’t seem to be a safety issue as I see a threaded bolt under the washer leg that seems to be the safety workaround. It just doesn’t seem to be catching. Is it possible something broke in the first 5 minutes? Any input welcome! Thanks in advance! -Kelly
