Maytag Push Button Washers
Chetlaham
Mar 11, 2013
5,490
United States
Does anyone have pictures or sales literature of those push button Maytag washers from the 70s and 80s? I've never seen one in person. They were rapid advance and to my knowledge had no electronics.
My Maytag has pushbuttons for water temp and fill level, and the mechanical timer.
Oh, and now a new pushbutton to force warm rinse. ;)
There are many posts on AW regarding the rapid advance Maytags.
Originally debuted in 1960 as the model 160, it was switched over to the A900 model in late 1961, with the A902 replacing the 900 in '64. In 1966 the A906 replaced the previous versions, which included the change of button color from grey to white and featured the large capacity tub. The A906 had a few revisions to the timer in the late 60's and was fully discontinued by 1972.
Ben
Thank you! The A906 is exactly the set I had in mind. I remember seeing the adds but latter could not find it. The service manuals I have don't seem to cover it. I wish I could find one to play around with and use because I think they are just so cool. I kind of like the idea of just pushing a single button to start the cycle even though I typically prefer push and twist knobs.
Question- the cycle says 40 gallons while the rinse says 19 gallons. That means only 2 gallons of water are used for spray rinsing? Or does 19 gallons pertain to both the rinse and spray? How many gallons to fill the tub to full?
I can't thank you enough for the pictures.
19 gallons for a full tub of water on the '06 models, 16 gallons for the 160/900/902. I think spray rinsing is affected by water pressure so there's no defined specification. Also, cold vs warm spray rinsing affects total water usage. My gripe about the push button models are cold spray rinsing with warm water washes. Only a warm spray rinse is used when selecting a hot wash. I get around it by selecting a hot wash 1 minute after the timer motor has advanced (doing it sooner causes the timer to completely reset itself). They're an interesting design but too restrictive for me, personally.
I've noticed that if you time the cold and warm fills to full, you can get a good guesstimate of how much water is used during spray rinsing.
I do agree with you that all rinses should be warm except Permanent press and bright colors.
I'm fine with a cold spray rinse on a cold water wash, but a warm spray rinse is better for warm and hot washes.
Maytag should have fitted these with more options. A separate infinite water level adjustment. Separate cold/warm spray and deep rinse switch (like the 142/700/702 models) and a prewash button. They could have removed the Permanent Press button and used it as a Prewash like the 806 models where it would fill, wash for 4 minutes, drain, fill, agitate for a minute, soak for a few minutes, and then go on with the normal wash cycle. It would require another dose of detergent after the first spin though.
The A9900/LAT9900/LAT9904 electronic units had pretty good flexibility except they all spray rinsed with cold water like all Maytag helical top loaders made from the 12 series in 1984 to the end of production in 2006.
I'm with you, I prefer a warm spray rinse. More water and in theory it relaxes the fibers more taking more detergent with it. It would be interesting to do an experiment whether or not cold vs warm spray rinsing makes a huge difference as it does with a deep rinse.
And that is why I modified my A482 with that extra button, indicator light, that forces a Warm Spray and Deep Rinse if set for hot or warm wash.
The cold wash is not affected, so it uses a cold rinse.
And if that extra button is not pushed, the machine acts as before the mod.
Relatively simple for me to design, and makes me happy.
Maytag all pushbutton automatic washers
On the original 160 model, they used a three valve inlet valve and all Maytags had the flow washer on the outlet of the inlet valve so it makes no difference whether it’s filling with hot warm or cold water as to the flow of water.
On Later models with a two solenoid inlet valve it still made almost no difference whether it was filling with cold or warm for rinse. This flow is about the same, 2 gallons is about right for the spray rinse. It was always too bad. Maytag didn’t have a spray rinse in the final spin to help wash some of the scum and such that got plastered in the clothing as it went into the spin cycle get flushed, away whirlpool of course did that on the direct drive machines because they learned this was a problem potentially with any washer.
The suds saver option was discontinued by the 906 series. The earlier models had this option. I had a 160 S that I sold to a neighbor with a large family. They ran the wheels off that thing it lasted until almost 1990.
John L
    2.2 MB
The Maytag push button washers didn’t nearly have as much flexibility as the 806 which was a step down.
The Maytag 806 was like the Whirlpool Imperial in terms of options, had separate temperatures and more wash times available.
    4.1 MB
I have been using Maytag pitman transmission washers for a solid 40 years, still waiting for scum to appear on the final load.
I don't want a spray rinse in the final spin to wash out my fabric softener. Neutral drain machines require them and they still accumulate nasty buildup in the upper tub, regardless.....especially DD's.
All top load washers ever built that had the ability to do a neutral drain did so.
I trust the engineers and the laundry specialists and the home economist at these companies who have all come down in favor of neutral draining.
I also trust my Long experience with working with customers and seeing the problems that are sometimes caused by spin draining.
Every top load washer sold today does a neutral drain except the TC5 Speed Queen series, and it does a neutral drain in Australia, and Canada and other places where clothes Dryers aren’t common which helps conceal the redeposited lint problem.
I have never seen any difference in redeposited scum, and crud on the outside of tubs and on the inside of outer tubs on machines that spin drain versus to a neutral drain.
There have been plenty of pictures. I have posted some of Maytag dependable care machines that were gross mess in the outer tub and on the outside of the wash basket as well as GE filter flow machines and other brands as well. It really depends on the way the machines used.
John L
The only gripe I have about machines that neutral drain is they have a tendency to suds lock, however I haven’t really had that problem on mine since the console I transplanted on came from a 18 pound capacity machine which had a 4 minute neutral drain. Since it’s a 4 minute drain on a smaller 9 pound tub, the suds usually settles down therefore no suds lock, or rarely ever suds locks.
The only area where spin drain matches are good is less complexity, no solutions to engine or a neutral drain pack, just reverse the motor and release the brake.
Since I have experience with both Maytags and my Whirlpool, they both have their idiosyncrasies and quirks.
I would think that using a low-sudsing detergent would help.
Suds don't clean, the detergent's chemical makeup does.
