Maytag Transmission grease?
horvik
Oct 13, 2018
0
Chiraq
Hello;
I notice some grease discharge underneath my 2 belt Maytag washer. How normal is this, and is there a way to check and refill?
thanx
Sounds like the lower o-ring seal is starting to go. You can get away with running the machine like that for a few years if the leak is slowly seeping.
There's no way to check or add oil without removing the inner/outer tub and cracking the trans open. If you go that far, might as well remove and disassemble the trans, replace the o-ring, and fill it up with fresh oil.
It's probably better to do the repair in the not too distant future if you want to keep the machine. Whirlpool has pretty much discontinued just about everything for these machines and the parts that are floating around out there are pretty much all that is left for us to use. To top it off, most appliance parts outlets have been throwing away the old parts to make room for the newer model machines. It's this reason I've been aggressively stock piling parts the last couple of years.
the o ring job is not to bad tags are easy. did mine about 2 years ago and found all the parts online even the oil. you can always make a gasket if you have to from that sheet gasket stuff at the auto parts store
