philr
I've been searching for a glass touchpad for my GM Frigidaire RCM-10 Touch-N-Cook microwave oven as the one on mine has been replaced a newer WCI RCM-10J glass (essentially the same MW but with start/stop/light buttons moved to the same location as those on Amana Radaranges). I finally found one. But I don't think I'm going to use it as it came with another microwave...
It works great but just like it did in my other one, the stirrer doesn't turn so I'll need to fix that! Any Amana Touchmatic owners experienced the same problem? The white plastic guard under it seems to distord a bit over time and that causes the stirrer blades to touch it and it stops to turn. But that's was quite an easy to fix in my other range!
