morellihugo
- Joined
- Jul 25, 2025
- Messages
- 3
Hello everyone! I wanted to share an intermittent drain issue I’ve been having with my washing machine.
When the issue occurs, it always starts during the rinse cycles and sometimes continues into the final spin. In some cases, the washer drains correctly between rinses and during the final rinse. Other times, the drain pump seems to run continuously but is unable to fully drain the water—there’s still a significant amount left in the drum.
There are also occasions where it drains partially, but after the final spin the drain pump keeps running nonstop until we open the door.
I’m trying to figure out what could be causing this intermittent draining behavior. Any ideas or similar experiences would be greatly appreciated.
