I'm looking for some advice from the Miele washer experts here. My (now) 15 year old Miele W1930 washer has recently developed a water intake problem. When filling with cold water; for example, a cold/lukewarm wash or any rinse cycle, the "water intake problem" light will rapidly flash. Some times, the washer will continue to slowly fill and resume the cycle, and sometimes, it'll shut off mid-fill; perhaps that's built in to the diagnostics when the pressure is too critically low for operation.I then have to drain and spin and hope that something got clean somehow.
What I've done thus far is removed the cold fill hose from the spigot, and thoroughly cleaned the penny-sized white plastic mesh filter on the spigot end of the hose. I also changed the supplied black rubber washer, since it had been grossly flattened from 15 years of use (with no leaks!) and had gotten much larger; perhaps, I thought, further restricting the water flow into the valve. No such easy fix luck. The owner's manual indicates that I should NOT attempt to remove the second filter within the water intake valve (?), so I have not done so.
My question is: where do I go from here? Is the cold water intake valve shot? Is it just the filter that might need replacing, or is the secondary water intake valve filter built into the water intake valve? Are these water valves/filters/whatever still available on a 2004 model washer? I really don't want to ponder a replacement Miele set for 2019.
The washer and matching T1520 dryer have never given me a minutes' problem, unlike the Premiere Plus Miele dishwasher that's long gone from the scene.
