Mildew Problem
jasonlsangel
Active member
Oct 28, 2005
25
Hi,
We have a mysterious problem with just our towels and washcloths getting a mildew stench that doesn't go away, and they are newly washed and dried. Any Thoughts?
Bri
Bri...Had the SAME prob here in Atlanta..Of course I consulted this forum and low and behold the problem has improved!!....I add Lemon Pinesol to the wash cycle OR the original Lysol liquid...kills whatever is causing the smell...
My guess:
High ambient humdity in the bathroom, so the towels & washcloths don't get a chance to dry properly after use. Then over time they grow whatever-it-is that's making them smell bad.
Then you wash & dry them, but the nasties somehow manage to cling to the cloth, and after they're dry, the bad smell is more likely to get into the air just as dust is more likely on a dry street than a damp or wet street.
So yeah, nuke 'em with whatever the folks here recommend, and see what happens.
The bad news is, you might have to nuke the rest of your clothes for a few months to get rid of any residual nasties that transferred to them from the towels & washcloths.
The good news is, whatever it is, probably isn't terribly dangerous since it hasn't made you sick yet. (Look out for athlete's foot and itches & rashes in sensitive areas of the body, in which case keep those areas especially clean, and keep them dry using baby powder.) Though, still a good idea to sanitize everything, because you don't want to go taking chances.
Preventive measure: do whatever possible to reduce humidity in the bathrooms. Including placing a small fan at the bathroom door blowing ambient air in there so the place dries out faster after showers.
Hi guys, I have this problem also but it seems worse on certian cloths and towels. Might be the fabric content, but the tags are gone so I cant verify that. Of course Designgeek is right, It`s worse when I`m not running central unit, like now.
Similar problem....
I tried a few things from my own ideas and thoughts from folks here.
I noticed that I would do a load of clothes, and as they were drying in the dryer, the dryer exhaust had that "mildewy" smell...yech.
So I ran three loads of hot water with bleach through my washer. Then I flushed it out and washed it by hand. Then I ran a load of Cascade Complete with the hottest setting through it.
BOOM it was gone. Suddenly my laundry was starting to smell better too, more of that fresh sent.
I then moved to Gain powdered detergent, from the liquid I was using, just for laughs and to see how it would perform.
I have heard of mold growing in your washtub, and these type of fixed kill it.
There are other way more informed sources on this topic, and I know that they will chime in shortly.
MOLD need to grow ...................
Mold need I believe at least one of the three to grow or maybe a combo of two ........... dampness, darkness and stagnant air ............ even having a light on and air constantly moving in a damp environment can reduce mold and mildew growth. Lysol is great at killing mold and mildew ..........
Lestoil is also a great, heavy duty, pine scented cleaner.
Bri, y'all have a HE3, not a HE3T. So, undoubtedly your hot water iisn't as hot as it should be because so little gets to the machine and overcoming the cooler components as well as the fabric.
I'm pretty sure y'all do this, but make sure the awsher door stays open after use all the times. And run the machine empty with Cascade complete. also make sure the gasket at the front of the door opening doesn't have mold and mildew around it--it'd be slimy, yucky. That will have to be rmeoved with a mild bleach solution by hand. And if ya do a lot of cold water washing, this just exacerbates the problem. Bob
When I was living there, *I* left the door open, did a warm wash first so the whites would get a good hot wash. But their hot water isn't very hot either, it's turned down. Saving energy I guess.
I dunno how much heat is needed to kill mildew, but would drying those towels on the highest heat to the Extra Dry setting be of any benefit? F&P suggests in their User Guide for the DEIX1 (new SmartLoad dryer on the NZ/Aus market) that linens to be shelf-stored be dried to the Extra Dry setting. That model also has an Allergy LifeCycle that uses high heat to help "ensure that dust mites and bacteria populations are decimated."
Please rinse well- and do an extra one for me. Lestoil is a petroleum distillate (read: nasty chemical). Same as Lysol liquid etc. The anti-mircobial qualities make me wanna rinse that one extra times as well!
Real pine oil, unadulterated, I believe works well as a disinfectant AND cuts suds.
I dry the towels here on high/more dry. Nothing I hate worse than trying to dry off with a wet towel. Same for underwear and wash clothes. Hot as you can get for tap water, bleach, high/extra dry. Best you can do on a set of T/L elites.
Jason,...need to ask you a question concerning your TL Elites.
I have a 2003 KM TOL 90 series which would have probably been considered an Elite before they came out. Anyhow, are you satisfied with the cleaning performance?
The agitator on mine is the triple action spring loaded one.
Your machine has the total care with the auger coming all the way up to the top..also spring loaded?
I ask, because our machines are very similar and for the most part i am generally happy with cleaning performance.
The real question is though,...which washer cleans better do you think, the Frigemore or the TL Elite? Would love to hear this answer. Thanks
Pat/Agiflow
Dear people, we in europe have internal waterheaters. My huseband plays soccer and he left last week his bag at the soccerhome. Result: all his towels had green spots of mildew. Well I washed it on sanitary cycle at 200°f. No smell, no spots, just nice towels. And no special additif just my usual product.
