Minty! GE electric stove
Looks Like:
An update of the J 370 I have. I copied the photos and blew them up, and I can see that while this one does not have Sensi-Temp, it does have Coil Select, re-named Power Saver. It's the same selectable coil size idea, so that you can heat a 4-inch, 6-inch or full 8-inch area of the burner.
I cannot tell if the range uses trim rings with separate burner bowls, or if it uses the updated one-piece bowl. I'm also unable to tell for sure if it has a light for the cooktop, but it looks as if it might.
I say someone needs to visit the Cities and get this baby! P.S.: Double-check the color - ad says White, photo looks like possible Almond.
