Modern Day Appliances
Or lack of expensive advertising campaigns. Word of mouth works wonders.
Yes, poor wages are a problem with offshore manufacturing. But I haven't seen any specific allegation that Danby is using sweatshops. If that's of concern it should be investigated further.
After monitoring the Danby during several cycles, i've never seen water spray out of more than just one hole [the same one every time].
But if i ever do see it come out of the other, i'll update you guys :)
Johnb, I assume you're talking about those two holes in the top rear of the cabinet, right? (Clearly the lower spray arm must be spraying out of all its holes otherwise you'd have called for repair.) Curious; I wonder what that other hole is for...?
Perhaps we can get a technical service manual for these and discover a few things?
