Hi all,
This is my first post here
I'm sure there have been posts on this topic before, but I couldn't find a comprehensive post on the topic - just random complaints here and there.
Anyway, I'm in the market for a new washing machine, and am trying to sort through what's real and what's marketing BS.
All of the review sites (e.g., Consumer Reports, Reviewed.com, The Sweet Home, etc) claim, in the strongest terms possible, that TL machines are worse than FL machines in every respect.
However, I am wondering if the testing methodology used to arrive at this claim is slanted - perhaps heavily - to favor the new eco-friendly FL machines. I've listed a few of the possible reasons for this below:
1. The cleaning tests appear to always (?) use a cold-water wash rather than warm or hot.
2. The "standard" cycle time is always (?) used to determine cleaning ability. This favors the longer cleaning time of a FL machine over the shorter cleaning time of a TL machine.
3. Soaking ability of TLs is disregarded in determining cleaning ability.
All of the above points seem to result in cleaning ability tests that consistently show FL machines cleaning much better than TL machines. However, this ignores the fact that TL machines probably *can* clean as well - or better - than FL machines if the testing method is altered. For example, what if the TL machine was filled with hot water, oxyclean, and the soiled fabric allowed to soak before washing?
In short, it seems to me that the inferior cleaning ability of TL machines may be the result of the testing method rather than inherent inferiority.
Moreover, the review sites mentioned above seem to heavily weigh the eco-friendliness of washing machines. They claim that some new FL machines use over 75% less water and energy than TL machines. As far as I can tell, this claim is true. However, the implications derived from this truth seem to be greatly exaggerated - probably on purpose. In other words, it sure looks a lot like propaganda to me.
For example, compare the 2 energy guide stickers at the bottom of this post. The first is for a cheap ($500) Samsung FL. The second is for a Speed Queen TL. You can see that, indeed, the Samsung uses 30% less electricity than the Speed Queen. But the point that all of the review sites omit - glaringly - is that the yearly difference in energy use is just $4 with an electric water heater, or $2 with a gas water heater. Unless I am misunderstanding something about the way that the Energy Guide stickers work, there is NO FUNCTIONAL DIFFERENCE in the cost to operate the "inefficient" TL machines relative to the eco-friendly FL machines.
With that said, I don't think the Energy Guide sticker accounts for regular hot or warm water washing. However, this cost is marginal if one has a reasonably efficient water heater (natural gas or electric heat pump).
The review sites also tout the vastly reduced water usage of FL machines (a datum not mentioned on the Energy Guide sticker). Again, this appears to be a fact. And again, this appears to make almost no difference in cost of ownership for most people with normal access to water. Water is very inexpensive in most parts of the country.
Finally, the review sites seem to give short shrift to the common complaints about FL machines: they mold, stink, and leak. Also, as mentioned above, they cannot truly soak clothing.
What do you all think? Is there a vast left-wing conspiracy against clean clothing? Are FL machines actually better than TL machines? Or are my feelings that I'm being misled justifiable? Thanks for reading!
As an aside, I can't understand how Consumer Reports gives such low ratings to Speed Queen machines. The SQ TL beats the #1 rated FL machine (Maytag) on vibration and gentleness, and also cleans in 1/2 the time (35 minutes vs 70 minutes). Unsurprisingly, the SQ has slightly lower washing performance (due in part, at least, to the much shorter cycle time) and the worst possible ratings for noise and water usage. Consumer Reports gives the SQ a score of just 41 to the Maytag's 86...but based on the separate criteria that comprise the score, this vast difference in score makes zero sense. So...propaganda?
