Modernising a vintage machine
adam-aussie-vac
Dec 14, 2017
1,092
Canberra ACT
Hey guys, I haven’t had really much luck with the Naco washing machine, So I’m thinking about if it’s possible to modernise the shaft seal after I replace the bearings in the Naco, I’ll have to have quite a bit of hunting around to see what kind of seal I can use, i’ll have to remove the bearings so I can get a model replacement for both the front and back bearings, does anyone have any suggestions on how to remove the bearings and the bearing cage? As the front bearing came out when I pulled the drum out
