well, for better or worse i bought this one yesterday for 75 bucks up in lima ohio. saw it on craigs list and thought it was an 18" wide D&M machine like sears and other brands used to have.
montgomery ward "signature" "mini maid" dishwasher and i have never seen one like it before!
does anyone here know who would have made this machine?
the model no. is shown in this pic and i can't find anything about it on the web. even called larry at modern parts house in cleveland and he never heard of it! that was a surprise, i thought if anyone would know about it's origin he would!
am trying to find out if there are any parts anywhere for it because it leaks! bad!!!
all i found was a motor shaft that goes down thru a rubber like boot about 1/2 inch thick and then into the top bearing of the motor! it doesn't look like anything could be replaced even if i could find a new part.
the only other pumps i have seen use these rubber boot like seals are on small drain pumps used on dishwashers and washers. i never expected the main pump on this dishwasher to use this type seal.
had i have known this i probably would not have bought this machine because when i put it all back together and tried it out it leaks badly!!!
