lucas0830
Active member
Good afternoon,my washer had a slow leak coming out of the Tub Bearing.I did two load's of wash and ordered the Tub Bearing Part #6-2040130,its was the orginal OEM part.Also ordered the Mounting Stem and Boot Kit Part#6-2095720.I remover both drum's and cleaned the bottom drum up real good and re-installed the new Tub Bearing and Mounting Stem.I did not lube or oil the transmission shaft,the videos I watched of the appliance guy's,did not lube or oil the shaft.The transmission shaft was in good shape,just used a fine emery cloth and put the new collar on the transmission.Then put the Tub bearing on with no probelm.Went to install the Mounting Stem and Boot Seal and the instructions where not clear on where to put the Teflon Ring.There are two side's to the plastic ring inside the Mounting Stem .One side has eight small dots and the other side is smooth.I put the teflon ring on the smooth side and snapped it into the Mounting Stem.Could not find a video on which way the teflon ring went in,installed it that way.Turned the washer on put it on spin cycle for 3 minutes like recommended.Then I filled the washer with water and the washer started leaking bad right away.I put the teflon ring on wrong.Went and re-installed the Mounting Stem again and put the teflon ring on the smooth side again,but now the teflon ring is facing the carbon ring on the boot seal.I now turned the washer to spin cycle for 3 minutes again and then filled the washer with water,and the washer started and I saw the washer was not agitating.I let the washer run for a minute to make sure nothing was leaking,and there was no leak coming out of the tub bearing.Question is if I have the Teflon ring on wrong would that keep the washer from agitating.I looked under the washer while it was running and the transmission belt was not moving,but the washer pump belt was working.I had my wife video the agitator inside the washer while I turned the transmission pulley .I turned the pulley clockwise and the agitator spun fine.Turned the pulley counter clockwise and there was alot of tension so I grabbed the transmission with both hands and turned it counter clockwise and the agitator was moving,but it was very hard to turn.I really like this washer machine,and would like to fix it.I was not sure if the plastic Pinion Gear could have broke or possibly a piece of old gasket fell off the inside of the transmission and jammed the gears,from the banging to removed the old stuck mounting stem or grinding and knocking off the old transmission collar.Also I was was wondering if the Upper Ball Bearing Radial part#Y200720 could be bad or seized from the water that leaked.I appreciate any advice or opionion on how I can go about repairing this washer machine.Thank You,Jerry
