Bonnie non-streak Blue
I was going through some neglected shelves in my basement and found a blue plastic quart bottle of this product. It has a wrap around paper label. There is a statement that it contains no Phosphorous. It was made by the J. L. Prescott Company of Passaic, New Jersey 07055. On the front of the label is the "Commended by Parents' Magazine" logo. There is no UPC code.
Directions:
For Tub Bluing add a few drops of BONNIE BLUE at a time, mixing thoroughly. When desired shade is obtained, add the clothes. Use too little blue instead of too much.
For Mechanical Home Washers. Mix the required amount of BONNIE BLUE with one quart of water and add prior to the final rinse water.
To Remove Accidental Over Bluing. Heat one quart of water almost to the boil. Remove from heat. Stir in 1/4 cup DETERGENT POWDER. (Do not use Soap Flakes or Soap Powder.) For cotton, linen and rayon, soak stained portion in solution for at least 10 minutes. For silk and wool, use slightly cooled detergent solution and soak for a longer period.
I remember the cork-stoppered bottle of Mrs. Stewart's. Mom kept it in a small plastic bag to avoid staining her fingers when using it. At my grandmothers' houses, adding the drops of bluing to the final rinse tub was an exacting task, but mixing it into the water was not because I was allowed to do that. Yippee, playing in water! An eye dropper would have been of such benefit for measuring the stuff.
There was a time when we had the '58 LK that mom used La France powdered bluing in the wash water.
