newwave1
hey folks,
well heres one of my collection thats been totally overlooked but happens to be probably the best machine i've ever had..introducing my AEG 74640
This machine is the most versatile i've ever owned.
its 1400rpm spin is extremely effective. it washes amazingly with its recirculatory jet and is well equiped for stains. with option buttons for pre-wash, soaking which can be anything from an hour to 19hours which compramises of a prewash & then tumbling every few minutes...a quick wash button for the lighter soiled loads, & a stain button which teamed with the in wash treatment compartment in the dispenser releases stain products at the right time in the cycle.
now heres for the interesting bit. when i first bought this machine, i read through the manual and found the "Rinse +" option. as i'm an avid fan of high level water rinsing & pre programmed this as soon as i got it. So this option adds 2 rinses & raises water level up considerably.
Now for what i discovered 3years after first owning it...this little beauty has a hidden rinse feature that has me amazed. which is what i've made a video of; when you DE-select rinse + and just make do with its normal rinsing....when the machine slows down from the spin after the first intermittent spin..it distributes and fills, just the same as jon (lavamat jon)'s 86741. now where our 2 differ is the interesting bit..once the machines finished filling...it tumbles for a minute or so...& then to my amazement...the machine distributed again pinning everythin to the sides of the walls of the drum with the jet on...& WHOOOSh the machine goes into orbit with a 500rpm spin!
it does this another 3 times in the rinse before draining, spinning and doin it all over again...i'm well impressed. because as little water it uses to do this, the results are amazing...that and it much reminds me of my old hoover newwave which used to do spin in the wash cycle
before i go on too much, i will let the video do abit of the talking
Ciao for now!!!
Darren
http://www.putfile.com/dazzaroo
Ciao for now!!!
Darren
