My Chandelier has just Died!
daveamkrayoguy
Silver Member
Dec 8, 2010
5,715
Oak Park, MI
It was a couple months ago, actually, that one bulb burned out in it and I never got to see the one replacement I had for it go on with the rest of the remaining bulbs there…
So, this only fixture and bulbs I could dig up went in its place…
— Dave
    3.3 MB
    2 MB
    1.9 MB
    1.8 MB
    1.7 MB
    166.4 KB
    1.6 MB
    1.6 MB
    1.7 MB
    1.7 MB
Maybe the replacement bulb wasn’t good? Did you try one of the working bulbs in the socket that had the burnt out bulb in it? It’s a shame to lose that nice chandelier. But the new simple fixture is nice too. We used to have one like your new one in our dining room and I replaced it with a chandelier about 10 years ago and replaced the on/off switch with a dimmer switch. Looks like you did a nice job Dave.
Eddie
    2 MB
Eddie
Well what happened was, I turned it on and one bulb was burned out, so then after replacing it, none of the bulbs came on...
I bought this beautiful light fixture more than ten-years-ago and I totally loath the idea of parting with it...
I'm quite certain what I put in works, but just as I heard that faint 'pop' as I turned it on to find all but the one bulb (it had a broken filament in it, while the rest remained intact) still lit...
However, after putting in that new bulb, and turning it on, the entire unit failed to go on... I heard another "pop" after which it had still just hung there dark and dead as a door-nail...
I have a dimmer switch there, too, none of the breakers tripped, (and resetting clocks and even my computer and phone and other communicative electronics proved not to have bothered there--though I had to trust there was nothing electrically-active when I unwired ands took down the fixture and wired in the new one, putting it up without a shock, while relying on the switch to be fully off)...
Just saw the opportunity to troubleshoot a little with it and needed light...
That desk lamp that tipped over with an ordinary incandescent bulb got put on another desk without a bulb in it after it had been taken off, and then I realized it, now stable, I could light that part of the room, the den, with the LED incandescent that was underneath that chandelier in the spotlight housing via a three-way-switch... And that also failed to illuminate down there as well...
Maybe I will take the whole thing to a lamp/lighting repair store to see what it can do...
-- Dave
It's very strange that the entire fixture would stop working when you replaced the bad light bulb. Once in a while, a bulb burning out will trip a breaker, especially the AFCI type, but you claim it did not trip. You state that it has an integral switch to select the candle sockets around the perimeter, the center down light, or both. It's very possible that this switch has shorted out, which would make a "pop" sound. Another possibility is that a splice burned in two, either in the fixture near the switch, or at the junction box in the ceiling. However, if it was in the ceiling box, you likely would have noticed the bad connection when removing the fixture, and installing the new one. Whatever the cause, it should be able to be repaired at reasonable cost.
