Wow Scott, very cool set, especially the Avocado!! That's the same set that appears in the POD occasionally, except yours has a temperature control...nice feature! I love these machines...fun to watch, not bad in cleaning ability or water extraction, and dead reliable!!
I have the later version of this machine, in white, with noticeable differences. It was made by Hitachi...check the cord or plug on yours and it will tell you. Instead of a steady, slightly angled stream like yours, mine has a "shower-spray" fill, the tub assembly is a little different (it still has the "vortex ridges" like yours), and it has a blue 4-vane impeller. And of course the appearance of the control panel and timer are different. I'll post more pictures in a different thread.
Does yours have neutral drains via a separate electric pump, no first spin, and the "clanking" tub brake? If the mechanism on yours is the same as mine (which it probably is), it's interesting to see with the back panel off. The impeller/tub are belt driven, and a solenoid pulls the "rocker arm" out of the brake assembly for spin. There's no reduction gearing so the tub spins at the same speed as the impeller does while washing...in other words, FAST. I'm thinking it's around 800 RPM, but I'm not positive.
--Austin
