my 'new' television
classiccaprice
Jun 26, 2007
2,059
Hampton, Virginia
Hey Fellas,
Some of you may recognize this, but I picked this baby up from another member on the way back from a wedding a little over a week ago. I was hoping to clean it up before posting, but with the end of the year teaching and all I don't have time.
It's a 1953 Zenith Sutherland as seen in the attached 1952 broshure. Here's the story, best I can figure. The Zenith was bought new in Atlantic City, NJ in late 1953 (the origional bill of sale and broshure are on their way from my friend), it then somehow worked it's way down to south Florida and was sold in a thrift shop in 1980 for $50. The lady loved it and took good care of it, but she died a few years later and the house was abandoned. There it sat for 20+ years until someone got hold of the house to fix it up. It was rescued and put aside since 2005. I picked it up and plan on restoring it. I have several projects myself, but the price was right (free) and I love the unit. This is my first vintage television.
So my question is, where do I start? I know the cabinet will need refinishing and I will have to make new feet for the unit (they have some rot from sitting on wet carpet from a leaking roof for so many years). However, I can do that part easily. Is there a site or book for learning how to fix a 55 year old console? I don't dare plug anything in, someone reportedly did when the unit was taken out of the house and the radio smoked.
Thanks fellas.
Good Hunting, Will!
What a nifty find.
You've sort of got your work cut out for you on that cabinet, but there are some things that will help.
First of all, it looks like you've got some veneer repairs to do. If you need to know where to buy veneer and how to work with it, please feel free to email me privately and I'll gladly share some resources with you.
From what I can see in the pic, you don't really need new feet, unless there is actual rot that I can't detect from a photo. If water staining is the problem, there is a product available in better hardware stores called oxalic acid. It comes in a powder; you mix it with water. Allowing a solution of oxalic acid to sit on a water stain bleaches it out. You should follow the instructions on the package closely, and be prepared to apply more than one treatment, waiting a day between them.
I can almost guarantee that the finish on that cabinet was originally lacquer. Deft brand spray lacquer is great stuff; it replicates a "factory finish" with excellent fidelity. You need to shoot multiple coats of lacquer to build up a sturdy finish layer; count on at least 6-8 coats. It goes on very thin, and dries almost immediately, so recoating is fast.
After the lacquer goes on, it needs to be rubbed out to eliminate imperfections, and to give the "glow" you see on better furniture. I use Brasso and old T-shirts, plus a heapin' helpin' of elbow grease. If you do this step correctly, you'll have a finish that is very difficult to tell from a factory finish by Drexel, Henredon, etc.- which is about the right quality of finish for your Zenith. In those days, Zenith didn't fool around when it came to the quality of their cabinetry. Only DuMont and Capehart were their equal.
Again, if there's anything I can help with, let me know...
Very cool WIll! You do have your work cut out for you, but what a beautiful antique you will have. I know you will have fun with that. Robert restored an earlier round pix tube model, so I am sure he will be lots of help with how to get started on the electronics of your Zenith.
I've already contacted Robert about advice on how he restored his '51. Though if he has more he'd like to share I'd be very happy to hear it! Thanks for the luck fellas, I'll need it! I took a break and cleaned up unit. If only the finish looked like it did on the inside all over. Boy, it's gorgious in there. Oh well.
Assuming that work/life don't intervene, I'll test the vacuum tubes this weekend. Does anyone currently in Va or planning a vacation to the area know how/have a tester for the picture tube?
Also, I asked on a previous thread, but forgot who offered to look up the sams photofacts for me. They aren't at the local library. If not, I'll find them online. Thanks fellas.
I took the cobramatic out and have been working on it. The cords shot, so I've got to replace that.
A few questions:
Is the motor supposed to be white? I've never seen one that wasn't black... I'll have to take a picture and post it.
How do I re-felt the turntable? What kind of glue do I use? Thanks
Isn't the tracking force on the Cobramatic tonearm quite high? Our neighbors had one when I was growing up and if you played a record on it more that a few times it would literally turn white with a lot of black dust all over the inside of the turntable area.
It depends on whether the Cobra was for 78's or 33's and 45's. I had a Cobra that was for all of the speeds and it tracked just fine and not too hard. Make sure you get the proper cartridge for it. The red cartridge was for the 78's, the red/green was for all speeds. They are available again on the internet. I don't remember the color of my motor. Sorry. They are a great turntable!
Black dust in the TT area-first thought-bad stylus.The tip of it is cracked or broken instead of rounded-If you look at a good stylus(needle)that would be the case-a bad one would have the broken tip-thus sharp edges which "cut" your records.The TT owner should replace the stylus IMMEDIATELY before damaging other records.Remember when Hi-Fi shops and electronic parts stores had stylus microscopes?You could then see the broken stylus tip-and in the cabinet under the scope were replacements.
White motor-Corrosion-is the white a powder on the metal surface of the motor?
Thanks Robert, I may have some specific questions regarding your restoration, that I'll send them via email.
I seem to have misplaced my digital camera, so pictuers of the white motor on the player will have to wait.
I unfortunately don't have an email account that isn't free (audiokarma won't accept members with free email accounts). If anyone cares to help me out with that, i'd appreciate it...
Anyways I did get an antiqueradios.com page, you can see the post on my player below.
http://www.antiqueradios.com/forums/viewtopic.php?t=90245
