Need Help Quick with Maytag A612 Washing Machine
dangerboy
Feb 16, 2017
52
Calgary, Alberta, Canada
I'm in a bit of a bind with the Maytag A612 washer that's in my cabin. The renter who was in there last week called me late last night and told me the machine just shut off in the middle of a load and they couldn't restart it. They said they would try to get it working again and would call me back. I didn't hear from them afterwards so I assumed they got it started up again and everything was okay.
It turns out they didn't get it going and my next set of renters came in today (Sunday) and found a load of towels and water in the machine and another load of bedding and towels in the basket waiting to get washed. I HAVE to get that machine working again so my renters can wash their bedding and towels. The problem is, I'm 400 miles away and can't get out there to look at it.
My guess is that the load got unbalanced and this is why the machine shut down. I got the new renters to take the load out and move the drum around and try to restart it but that didn't work. They also tried unplugging and plugging it in a couple times but that didn't work either. I don't think the breaker has blown as the lights in the utility room are working and I think they're on the same fuse as the 120V outlet that powers the washing machine.
Is there a specific reset procedure for those old machines? If yes, what is it? If there is no reset procedure for those machines then what else might be the problem? They've tried moving the dial around and pushing it in but the machine shows no sidn of life. I'm really hoping it just needs to be reset because my cabin is in a bit of a remote location and finding a repair technician who will go out there is going to be difficult and costly.
TIA
load got unbalanced
Sounds like it shut down during agitation since it was found with water in the machine. Unbalanced loads typically occur during the spin cycle and are easy to correct i.e. redistribute the clothing and restart.
This isn't likely something your renters are going to be willing and able to fix.
Probably cheaper to bite the bullet and have a new machine delivered out there and work on the Maytag later.
Have your renters turn the dial all the way to the final spin position, and see if it shows signs of life when the knob is pulled?
It's not likely that it tripped the imbalance switch, as opening and closing the lid again would have reset this.
It's not likely to be the motor overload tripping, as the renters would have commented on the obvious squealing or buzzing sounds that would accompany this (or the conditions which would cause it).
So what else will stop the motor? Not satisfying the fill level switch would. Not enough water, and the switch wouldn't energize the motor to agitate, nor would the timer advance, so it would effectively be dead (and silently dead). So that could either be a wiring fault, or perhaps a fault of the fill valve? Shutting off the house water supply would also have the same effect. The final spin doesn't care what the water level is, that's why I suggested that test.
And of course, checking the fuse would be a good first step, even if you do believe it is shared, just to rule that out.
The drum or whatever you call it is about 2/3 full of water with the laundry out so it got enough water in there. If the fill level switch was not detecting the water was there, wouldn't it keep filling it because it wouldn't know when to stop?
If the lid safety switch crapped out, wouldn't that cause these problems? From what I can find elsewhere on the net, it seems that this type of problem is often caused by a faulty lid safety switch so it would seem that this is the most likely cause or at least a likely cause. Agree?
I've found the part number for the lid switch for the A612. Where on that machine is that switch? What do you have to do in order to get at it? I have a friend out there who might be able to work on it for me tomorrow and bypass the switch to get the machine working until I get out there in a couple weeks.
To be clear, I was helping brainstorming possibilities, not providing a diagnosis.
It could be the lid switch, and it could be any number of other things. You will have to be on-site and open up the machine to diagnose, otherwise you are just firing the parts cannon and hoping for the best. If it was the lid switch, you could tell definitively in just a few minutes with a multimeter.
Please don't do this. The machine would no longer be able to shut itself down if it goes unbalanced again, nor would it have a functioning safety interlock to keep it from starting unexpectedly when your tenants have their arms in the tub. It might be something that folks here do to their own machines, knowing the risks, so that they can watch them run with the lid open. But for a rental property? No way.
The current renter's son owns his own auto repair facility so he's pretty handy mechanically. At my request, he got into the control panel and bypassed the lid switch and got the machine working again. At least they can now finish the bedding and towel loads left behind by the previous renters. I will get a new switch out to them ASAP. They won't have to do anymore loads until next weekend when they're finishing up their stay so they should be able to get the new switch installed before they have to do anymore washing besides the two loads that have to get done right now. Crisis averted.
In the meantime, to mitigate the risks, I will tell them about the machine not being able to shut off when the load is unbalanced and to make sure the load has completely finished all cycles before reaching into the machine and to be extra safe by always unplugging the machine before reaching into it.
Also, are we wure that machine won't still shut down in an unbalance situation with the lid switch bypassed? The switch for that machine is just a single switch that is also used as a dryer door switch. It's not one of those units that also comes integrated with another micro-switch and a fuse. (See photo)
I didn't realize that the lid switch and the OOB switch were the same thing.  They strike me as entirely unrelated components that would be triggered by entirely different circumstances.
Fewer parts = simpler machine, less wiring, lower unit cost, lower assembly costs, and improved reliability. It's a clever system, just with the downside that *everything* stops when you open the lid, even filling with water.
One additional benefit is that your out-of-balance switch gets regular "exercise"/testing. So if it fails closed (letting the machine run), you're likely to notice it in a way that you might not, until it's too late, with a dedicated OOB switch.
Cool.  Somehow they worked it on the 12 series (maybe the 10s too?) so you can leave the lid open while the tub is filling.  I like that feature on my 712.
Filling with the lid open - Maytag style
Ralph - you're spot on. Starting with the 10 series in 1980, the lid can be lifted while filling. I agree that it is quite useful and I wish Maytag had done the same starting with the 06 series machines in '66.
Ben
Maytag!
My family had a A810 purchased in 1981 and it stopped when the lid was open during the Fill period! I think it was the mid 80's when this was changed!
I’m far from being the Maytag guru but I’m pretty sure filling with the lid open started with the 12 series. I have a 1984 LA 710 that does nothing with the lid open and a 1987 A412 that does let the machine fill with the lid open. The 1987 A412 also still has the pitman transmission. This changed to the orbital soon afterward. As to the original post topic, glad you were able to get your Maytag back in service.
Whoops! April 1984 LTS
Well it looks like I'm caught with my foot in mouth. Y'all are correct - the fill with lid open feature didn't start till the 12 series. I must have been dreaming that the 10 series did this as well!
And - to the OP, I'm glad it was an easy solution that the tenant was able to self-serve. Those lid switches can be pesky and a real head-scratcher.
Ben
I played with an A810 12 years ago and remember the water valve cutting off with a triggered lid switch. As far as I know, the open lid water fill feature wasn't available until the 12 series washers unless Maytag introduced that feature on the very short lived 11 series machines (yet to play with one of those).
35 years ago I wound wire to the drain outlet to keep the lid switch connection open so everything works on my 511, lid open or closed, its always open when in use. If by chance it goes off balance, it slams the open lid into the timer and kills everything until you redistribute the load and pull the timer out to resume the cycle but I am always right there when I have any appliance running.
