Neptune Recirulation
Same reason they put a perforated tub inside a solid tub inside a fixed tub that caught the water spun out of the inner two; bad engineering unchecked by superiors who did not know enough about the concept to question it. It is similar to the reason why Frigidaire had such terribly designed dishwashers for so many years.
Neptune recirculation pump
When they installed recirculating pumps, it was made to recycle the water from the bottom of the pump.
When detergent is added to the dispenser, the soap immediately runs to the lowest point- which is the pump as well as the first of the water that enters the machine. Maytag fixed that problem by using 100% of the detergent that was added to the washer. Where before, some detergent was lost.
In the later years, they added a plastic “tray” before the hole in the bottom of the outer tub. It would catch all the detergent, the motion of the tub and water would eventually mix all the detergent.
Whirlpool Duet’s claim is direct inject. The water would mix a little in the dispenser and shoot it directly in the tub full of clothes. They also had a little plastic ball in the “hole” of the outer tub, as the water would raise. The ball would rise and “plug” the hole- in order to use all the detergent in the wash tub.
If I'm following the documentation correctly, recirculation was only on MAH4000 series 45+.  Not on the original MAH3000, MAH4000 prior to series 45, or MAH5500, 6500 or 7500.
Yes?  No?
Reply #4
Yes, just the MAH4000 has recirculation.
I’m not sure about MAH5500A as they were the last of the push button series. (It was in production for a short period.)
Tom - turbomatic
nailed it. It was a  modification after the 3000's because most of the detergent water sat in the sump during wash. Engineers should have read Bendix Doctrine, the answer was there all along since 1938 !! Bendix patented tub spacing because they knew that was critical to good cleaning. Damn Good Engineers at Bendix.
