Neptune TL & Drying Cabinet
DADoES
May 21, 2001
16,025
TX, U.S. of A.
Houston.  TOL FAV9800 washer with touch screen and water heating.  Rare set, but price probably is high even so.
Could be the referenced "sensor" the washer needs is the tub displacement (OOB) sensor.  I have a spare (installed, found it wasn't the problem, removed immediately), paid $57.94, will sell for $50 + shipping.
http://houston.craigslist.org/app/3270852883.html
TOL Neptune TL Pair
This is Modern Washer History, lots of you younger guys and gals are going to wish you had these some day, the asking price is not bad considering that these cost between $2400.00 and $2800.00 dollars less than ten years ago and it sounds like the seller wants get rid of them, so they could be an even better deal.
I Spoke to the seller of this Neptune on ebay months ago. I made him an offer of $50, he told me no. Said the parts were worth more than that. I said good luck and that perhaps if it were working, he could command that price. But no one was going to pay $350 for a science experiment. I see it's still up there.
A little heads up for you all...
Whirlpool has decided it would be fun to NLA most of the parts for the drying cabinet. Yes, these are not old at all. Yes, they cost a freaking arm and a leg. Yes, people had to frequently modify their laundry rooms to make it fit. All that means squat. The control boards are hard to get if at all and the element for the electric lower dryer is long NLA. There are aftermarket restrings (element only) which sometimes may fit but if you've broken any of the ceramic mounts, you're toast. The gas model is a little more forgiving as the coils and igniter are generic but the heating element/steamer tray assy that both models use for the upper cabinet is also gone.
Very annoying to say the least as the owners are, understandably, unhappy being told that their once expensive machines are now useless. Calls to the Whirlpool 1-800 line are also not very helpful. Pity. I almost got one myself!
Also, another heads up for all you MAH5500/6500 owners! The main control boards appear to be on a national back order with no release date. My supplier has called and seems to be getting the impression that there might be a vendor issue (as in the current vendor isn't making them anymore and another vendor is being sought...) and in the past when this has happened, Whirlpool will most likely just NLA the part and be done with it. As they were told, the release date could be in a few weeks, months, years or never... Time to locate a spare or two for all you happy owners!
RCD
As far as the Neptune T/L is concerned, the most common cause of a continuous out of balance condition is usually a failing clutch. This is easy to diagnose and repair. I haven't seen many of the sensors fail.
RCD
I'd forgotten all about the season or two that drying cabinets were the "new thing". Although their commercial existence was brief (didn't Whirlpool make one, too?) their collectibility rating is through-the-roof; especially when paired with the two-spinning-discs washer. Rare + rare = Awesome!
I do not understand why people just cannot bite the bullet and use a front load machine instead of trying to work against gravity with these HE toploaders. You need to use the same HE detergents with both. If the washers are mounted on a pedestal, all but the most morbidly obese can bend to retrieve items from an FL washer or so it would seem and the FLs are generally easier on textiles.
Man, that is one rare washer. If I remember correctly, it spins at a higher rate than the push board machines - 1000 RPM?
If I found one locally, I'd be hard pressed to not drag it home.
Andy - thanks for the heads up on late model Maytag parts. I'm not surprised but it is a huge PITA for those folks who shelled out some HUGE coin for the DC's. I saw an electric one a few months ago behind the local appliance store. I wonder if they weren't able to get parts for it either.
Ben
"HE" Top Loaders
Why? Because Americans by a good majority still prefer top loading washing machines. It is merely a case of appliance makers trying to give the people what they want whilst not ticking off the federal government.
A much more sane and logical solution would be moving to the popular design of top loading "H-Axis" washing machines commonly found in commercial laundries and on smaller scale from offerings such as Miele and other European appliance manufacturers. However there are two problems that come up at once.
Even the largest (IIRC 5-6 kilos) European models of top loading H-Axis washers would be considered too "small" capacity for many Americans. The other problem is once you start going into the realm of capacity expected for "top loading" washing machines on these shores (15-18 lbs) design problems creep up. To house a tub with such capacity it's likely the cabinet would have to be larger and or longer than the current standard for American washing machines. This could mean the unit wouldn't sell in great numbers.
Staber offers a "top loading H-Axis" washer but is frequently dinged by Consumer Reports and others regarding it's capacity. Whirlpool has held patent designs for years now on a similar machine but so far that is as far as they've gone.
Just To Be Clear - Everything Old Is New Again
Drying cabinets in one form or another have been around since the turn of the last century. Sold for commercial and domestic laundry use (Martha Stewart's former Ford Estate has them, as does the Vanderbilt mansion in North Carolina), they were basically racks on rollers that rested in a heated cabinet.
These dryers were used for hanging laundry either when outdoor weather wouldn't permit and or items that couldn't go into "tumble dryers" (yes they had those in commercial laundries since around 1920's or so),or simply to speed laundry day. IIRC in parts of the UK/EU drying cabinets styled like those offered by Maytag, Asko, etc... were modern versions of airing cupboards that one not only could hang wet laundry to dry but used to dry out damp boots and or outer garments. For places where the climate is damp more or less a great part of the year this proved a blessing.
IIRC there were small versions of such cabinets sold in the UK by Servis (?) and others. These looked rather like top loading dishwashers with a heating element at bottom and a series of removable racks that kept items suspended above the heat source.
