New GE Top Load Hydrowave Washers
Anyone see the latest offering from GE in their hydrowave line?? The newest machines now offer the option of a spray rinse only, similar to Fisher & Paykel. You also have the option to do a deep rinse (for those die hard softener users!!) as well as a second rinse. Not sure what the water consumption difference is, but the machines are on the floor in Lowes now. Whirlpool did this a few years back, without much success on the market, if I remember correctly. But how else can manufacturers justify continuing to make top loaders with the water efficiency regulations imposed on them?
Whirlpool's Resource Saver washer was a recirculating system, like the Catalyst pre-treating cycle on TOL models. It uses a diverter valve and the machine's pump to recirculate water through the clothes while spinning slowly. The reports I heard were pretty good but the machine was a bit ahead of it's time.
DADoeS, I have the agitator model of the Kenmore Oasis. It does a brief spray-rinsing phase before the first spin. Other then that it only does a deep rinse. Also, is this the washer you are talking about AndrewInOrlando?
No, that machine is the Harmony with the HydroWash wash system. It has a wash plate, not an agitator. GE's HydroWave has an agitator that makes a 360 degree arc, and is driven directly by the motor, without a transmission. They have 3.5 cu ft tubs.
Also, That machine is not the GE Harmony. The GE Harmony has the curved profile control panel and has a large LCD display. It does have the HydroView Glass Lid and The HydroWash system as well. It also has the HydroHeater water heater. If you want more information on the GE Harmony washer and dryer ask Unimatic1140. He owns the set. That machine is just the "GE Profile High-Efficiency Top-Loader". I think it is the GE version of the Haier Genesis washer. Here is a link to the Haier Genesis Washer and a Picture of the Genesis washer.
Foraloysius, I think that machine has been out for a while. I also heard hey are kind of crap. Yes Whirlpool did do that a few years back. It was the Calypso washer. It washed great and it rinsed... not so great.
Actually, it is....
That machine is indeed the GEHarmony without the touchscreen control panel.
Whirlpool's version was called the Resource Saver and it had a traditional DA Agitator. It was out just prior to the Calypso, if memory serves.
MRB
Well, Let's see about that:
Here is the list of the HE Top-Loader washer from GE's website:
$999 Est. Retail Price
Current Rebate
ENERGY STAR® Qualification — Provides less energy waste and lower utility bills
4.0 Cu. Ft. King-Size Stainless Steel Basket — Makes room for more items which means less time doing laundry. Plus, it allows easy access, without a pedestal.
HydroWash™ System with Infusor™ — Achieves frontload wash performance with topload convenience. Saves up to 14 gallons of water per average load and up to 90% energy.
HydroView™ glass lid — Allows you to view clothes during the cleaning process, without opening the lid or stopping the wash cycle
Direct-drive motor with adaptive spin speed combinations — Runs at just the right speed for optimal cleaning results
1010-RPM Spin Speed — Removes more water during the spin cycle to minimize drying time.
And here is the machine's specifications:
APPROXIMATE DIMENSIONS (HxDxW)
43 in x 28 1/4 in x 27 in
CAPACITY
Capacity King-size
Total Capacity (cubic feet) 4.00 cu ft
FEATURES
Control Type Electronic
Drive System HydroWash™
Energy Star® Qualified Yes
HydroView™ Glass Lid Yes
Wash Mechanism Infusor™
Washable Wools Yes
Custom Cycles 9
Cycle Countdown LED
Cycle Status Lights LED
Number of Cycles Multiple
Style Top-Load High-Efficiency
Wash Basket Type Stainless Steel
Wash/Rinse Temperatures 5
Wash/Spin Speed Combinations Multiple
Water Levels Automatic
Water Temp System RighTemp™
Active Wear Cycle Yes
Adaptive Capabilities Adaptive Fill
Specialty Cycles Yes - My Cycle
Whites Yes
Colors Yes
Comforter Cycle Yes
Handwash Yes
Heavy Duty Cycle Yes
Optional Soil Levels - Heavy Soil Yes
Optional Soil Levels - Light Soil Yes
Optional Soil Levels - Normal Soil Yes
Delicates Cycle Yes
2nd Rinse Yes
Delay Start Yes
Fabric Softener Dispenser Yes
Rinse and Spin (Quick Rinse) Yes
Soak Cycle Yes
Speed Wash Yes
Bleach Dispenser Yes
End-of-Cycle Signal Variable
ArmorGuard™ Protection Yes
AutoBalance™ Suspension System Yes
Lid Opening Top-Loading
Maximum Spin Speed 1010 RPM
ECONOMICAL / QUIET
Quiet Insulation Package Supreme
APPEARANCE
Color Appearance White
Color Appearance Code WW
Other Colors Available MG
WEIGHTS & DIMENSIONS
Overall Depth 28 1/4 in
Overall Height 43 in
Overall Width 27 in
Approximate Shipping Weight 155.00 lb
Net Weight (lbs.) 135.00 lb
WARRANTY
Parts Warranty Limited 1-year entire appliance
Limited 5-year suspension rod/spring assembly/main electronic control board/washer lid/cover
Limited 10-year outer tub/transmission
Limited lifetime of product basket
Labor Warranty Limited 1-year entire appliance
Warranty Notes For models produced on or after January 1, 2006
See written warranty for full details
Here is the features list for the GE Harmony washer:
HydroHeater™ — Increases wash temperature to reduce bacteria and provide better cleaning for the really tough stains
ENERGY STAR® Qualification — Means less energy waste and lower utility bills
LCD touchscreen with English/Spanish option — Users can select English or Spanish-language option as they select dry clothes
HydroWash™ system with Infusor™ — Clean clothes thoroughly and gently, without agitation
Here is the machine's specifications:
43.10 in x 28.20 in x 27 in
CAPACITY
Capacity King-size
FEATURES
Control Type LCD - Touch
Display Option English/Spanish Option
Custom Cycles Yes
Cycle Countdown with LCD Indicators
Cycle Status Lights Display Time
Style Top-Loading
Wash/Spin Speed Combinations Variable
HydroHeater™ Yes
Specialty Cycles Yes - Multiple
Whites Yes
Colors Yes
Dark Colors Yes
Easy Care Yes
Handwash Yes
Optional Soil Levels - Extra Heavy Yes
Optional Soil Levels - Extra Light Yes
Optional Soil Levels - Medium Yes
2nd Rinse Yes
Delay Start Yes
Extended Spin Yes
Power Rinse™ Yes
PreSoak Yes
PreSoak/Extended Spin Yes
Quick Rinse (PreWash) Yes
Second Rinse Extended Spin Yes
Speed Wash Yes
Spin Only Yes
Stain Wash Stain Inspector™
Color Lid Instructions Display
Color Stain Guide / Instructions Stain Guide
Front Serviceable Yes
Automatic Temperature Control Yes
ECONOMICAL / QUIET
APPEARANCE
Color Appearance Dark Platinum
Overall Depth 28.20 in
Overall Height 43.10 in
Overall Width 27 in
WARRANTY
Limited 10 year outer tub
Finally here is a picture of the black machine. As you can tell by all this, I highly doubt the two machines are both Harmonies.
About that "Whirlpool Resource Saver" washer, Is this it? This washer is known as the "Whirlpool Catalyst Gold" washer by the guy that posted these videos. This machine debuted the "Catalyst Cleaning Action" and it did come before the Calypso.
