Hi knowledgeable folk,
I really lucked out and picked up a never-been-used Kitchenaid KD-12P dishwasher. I’ve brought her home and am starting to evaluate what needs fixing. I want to plug the drain and let it sit with hot water to figure out where the seal leaks are. Since nothing has ever been plugged in or plumbed, any tips on how to test the motor and cycles once it is water-tight? Which seals do you recommend focusing on and replacing?
Not that we are anywhere near ready to install it, but I’ve also run into the issue that the flooring in my kitchen was updated to hardwood and the space under the counter is 3/4” shy of what I need to slide the dishwasher into place. Our modern POS washer has the bottom feet and wheels removed to fit it in. That is not an option on this unit. We may fabricate a shorter base to weld on while we wait out the llong-term goal of remodeling the kitchen around our vintage appliances.
I appreciate the historical posts about this machine and hope to add my experience and what I learn to the archives. Thank you for any advice you have to share.
