kevinpreston8
- Joined
- Jan 23, 2006
- Messages
- 371
I finally gave up on my 10 year old Eureka Victory.
It was never a super power house to begin with, but it had been cheap. Since my nanny started using it (blaming it all on her) she started to complain that it smelled every time she used it. Unfortunately, it was not a "burning rubber" smoke sound, but kind of a moldy smell.
I took the thing completely apart and soaked everything in Mr. Clean in the bathtub overnight (Lesson #1, don't assume your brush roller is plastic, mine was wood and went "out of round" and useless). Scrubbed dirt out of everything until spanking clean. The only thing I did not soak was the motor, foam around the motor, and the motor casing area.
Everything smelled great. Put the thing back together, ran for a few minutes, started smelling like mildew/mold again.
Replaced both filters, the out of round roller that made the belt smoke!, belt, new bag once again. Still smelled. Ran it outside for an hour! while spraying lysol around it. Seemed ok for a while, then it started again.
So, replaced the foam that wrapped the motor with new foam. Seemed ok. Vacuumed with it. Next day my nanny used it, started to smell again. Is she vacuuming up milk?????
Finally soaked the hoses (all dirt travels through the extension hose even if you are not using it) in a mixture of laundry detergent and bleach, overnight.
Started it up, it smelled like mold and laundry bleach! I had enough and tossed it out in the trash. I suppose I could replace the hose, perhaps mold is growing in the flexi parts of the hose inside, but enough is enough.
So.....
Went to Target and was unimpressed with all the bagless vacs they had. Went to a local tiny vacuum store where I have bought accessories for years, I may have even got my Eureka there.
The owner there seconded what I heard about bagless (which may not be true, but it sounds good) in that they lose efficiency right away because bagless or not, everything goes through the filter. So the first time you use it it slowly is becoming clogged. Then she has had people complain of mold because when you clean the filter with water it must be 100% dry before use, and they shrink, etc. Sounded like a nightmare to me.
So having very limited money to spend on this at the moment (yes I still do want an Airway or like vac in the future) I walked away with a Hoover Wind Tunnel 5200. It is the bagged version, despite the bagless sounding name, and it is 12 amp. It was $147. It has a regular filter but a Hepa bag. Here are my thoughts.
First, the thing is super heavy. It has to be 1/2 again the weight of my Eureka. When you remove the hose to do edges with the extension wands, you have to close a door over the hose connection otherwise anything that the rollers pick up as you move around blows up at your face. I already forgot to close the flimsy door once.
The flexible tube does not stretch very far so you have to use both pieces of extention wand. On my Eureka, you could leave one attached and ready to pull out to immediatly use, but not on this one. So quick edge touch ups are not so quick. It is very noisy. It does have another roller brush attachment for "dog hair on upholstery", but I have no idea how those rollers will work yet.
So, it is heavier, harder to use, less convenient than what I got rid of. The plus side is it was cheap and has the Hepa bag and an easy to replace slide out filter. It also has a light which I have never had. It is nice to vacuum with no smell. It also picked up a few styrofoam snakes and paper clips with no problem, something my Eureka could never do.
I am having a touch of buyer's remorse. Perhaps it will lessen in time.
So.....
