dustin92
I just picked up a new Whirlpool Belt drive (2010+ version) model WTW4800XQ2, and it is in really good condition, except for the fact that it doesn't work properly! The previous owner said it wouldn't spin "sometimes", so I connected it to water, power, and drain, and gave it a test- Filled fine, and that's where the poo hit the fan- the agitation started, but only in one direction- when it should have reversed to complete the agitation stroke, it kept going in the same direction (clockwise if I remember right) so, the water was just being whipped up the sides of the tub. I can see why it wouldn't spin- the clothes would likely tangle badly after several minutes of this action and throw the tub off balance when it came time to spin. I did (stupidly) put in an old sheet to see what would happen, and as I suspected, it wrapped around the agitator. I canceled the wash, and set it to a drain and spin cycle, and after unwrapping the sheet from the agitator, it went into the spin cycle properly and sounded fine. I can't seem to find any info on the issue by doing a google search- a couple of the same problem I'm having, but no solution. If anyone out there has any advice or info on the problems I'm having, anything will help. I'd like to fix it if possible because it is less than 5 years old and in good condition overall. Thanks!
