wp-dude22
Saw the new WP washers with Expert System here they are a bit on the pricey side but .... i would really like to see the wash action and the specs like spin speed on both.
One is the wash-plate model with glass lid the other is solid lid with the single action agipeller
The agipellers lower fins / stems are actually quite thick and a bit high so i would say more like fins than a wash plate but i would love to see it in action.
the regular wash plate model of WP washers are 5000+ TTD
So what i like
1) the stainless steel tub on both
2) the Wash-plate model actually has water level adjustment S, M, L, XL and intelligent load.
The wash-plate model ........
It has normal and high for spin speed.
The cycles run as follows :
Delicates, Dark, Jeans, Colours (Xpert Cycle), Whites (Xpert Cycle), Quick Wash, Underwear, Sheets, Towels, Bulky Items.
It also has a wash phases select button so i guess if u want a spin only or run you would power on the washer and use the wash phase selector to bypass a whole cycle.
Phases are as follows:
Soak, Wash, Rinse, Drain/Spin Done ... usual lid lock.
Temperature options are limited to three hot, warm and cold.
Soil level are high, normal and light
There is an alarm option which has end of cycle and rinse as options.
there is a dispenser for detergent and fabric softener usual pull out draw.
Agitator Model ....
IT has no temperature options so im guessing only cold (one water inlet).
Water levels: S, M, L, EX.
Cycles are as follows
Automatic Cycles
Delicates, Jeans, Towels, Bulky Items, Colours (Xpert Cycle), Whites (Xpert Cycle).
Additional Cycles are
Spin, Rinse & Spin, the others i cant remember ans the image is blurry lol will update.
Sound off
So what i like
Agitator Model ....
Automatic Cycles
Sound off
