The Maytag wringer washer agitator lint filter had the flat top like the early lint filter agitators for automatics. It was stainless steel with a rubber-like gasket at the bottom. The lint filter agitator in wringer washers was discontinued before the turquoise agitators, at least I never saw a turquoise lint filter agitator for a wringer washer. I wonder if the tall turquoise filter could have the dispenser hole drilled out so that it would fit down over the narrow shaft wringer agitator and work about as well as it did in the barrel of a Power Fin.
The lint filter agitator in a wringer washer washer was not much more than a gimmick since by the time darks were washed, the water was so slippery with detergent that lint usually would not stick to anything as items were lifted out of the water toward the wringer.
