I'm sick. We could have gotten this for $50 B/O but we can't make the wall oven work without building in a cabinet again, thereby closing in the kitchen like it was before. I would have even dealt with the 5 speed burners instead of infinite control. Here's what the seller had to say when I asked for dimensions and wiring pix:
"I pulled off the bottom pan and took some pictures. Good news and bad news. Bad news is the stove top electrical is taken apart. The good news is it appears all the parts are inside plus someone put in what appears to be a brand new wiring harness. They did not finish putting it back together. Other good thing which you can see in the pictures is this unit did not get much use based on the fact that it has little or no food residue on it. I think it would be a good project for someone who is technically inclined, is qualified to determine if it is safe to use and how to properly install it, and wants an awesome looking retro appliance. I dont want to put the range wiring back together and test it so the price does down to $50 or best offer.
I pulled the cover off the oven. It appears the wiring is intact.
The dimensions (inches) are...
Range will fit in approx 20.25 d x 29.75 w inch hole cut in countertop with radius-ed corners. The rim of the range is 21.75 x 30.75 inch, depth is approx 5 inches.
oven is 26 w x 32 h around front bezel. Cabinet is 24.25 w x 30 h x ~23 deep."
Good luck someone! This is a gem!
