I grabbed a terrible video of the machine running - all functions seem to work, the pump is quite loud but that wasn't too surprising so I didn't run it long. I have not put water in any part yet, I want to give it a more thorough check before getting it wet. The wash timer works at the delicate setting but then as it's turned past that point, the motor stops and doesn't run. I suspect there is a bad contact point inside the timer so I'll have to pull it out and have a look.
